I’m not sure if this is already in the works, but I came to realize that when I use extrude command (with gumball) on a single face with subD objects (also with surfaces and polysurfaces), there are no snaps available. This would be really helpful and would speed up the modeling so much, so I’d like just to add this as a feature request.
Hi @dusancv
I agree that snaps should work! As a workaround, if you use the gumball move arrow and press/hold control after you start moving the face(s), you should have osnaps working
HTH, Jakob
Yes, glad you share the same opinion. I’m not getting this workaround. The snaps are working in this case, but they are working for moving the gumball location itself, not the actual face.
Hi @dusancv
Strange - it works here. I’ve made a quick video. Remember, I’m using the arrow, not the extrude dot on the gumball. I’m pressing/holding Ctrl from around the 5 second mark - notice how the preview changes from moving the face to extruding it. Are you seeing any snaps if you just move the face (no Ctrl pressed)?
-Jakob
Yes, that’s strange. It may be a glitch. I am doing exactly the same thing as you. Not seeing any snaps both with and without ctrl pressed (using the arrow, not the extrude dot on the gumball)
