Does anyone have any idea how can I model this?
In Rhino 6 you can use Weaverbird to subdivide a mesh and then Fattener to create the “piped” structure
mesh_catmull_clark_fattener.gh (9.5 KB)
Oh my god! I am seriously soo stunned by your knowledge, @martinsiegrist Sir. I just couldn’t believe that you achieved the desired output in just a couple of minutes and that too by using very few components. I have been trying to make this geometry from a very long time and couldn’t achieve it! I couldn’t thank you enough for this. You are a gem, @martinsiegrist . Thank you so much for helping me.
PS. Could you please also achieve the below-posted geometry(Chhatrapati Shivaji Airport Terminal Columns by SOM Architects)
Thanks in advance sir.
Thank you. I’ve been doing stuff like that for a while…
The second example looks like a SubD based model.
The basic structure can be built with the part I provided in the example, just add planar meshes with the same number of faces in between.
mesh_catmull_clark_picture_frame_thicken.gh (18.7 KB)
It’s much easier to control which edges are smooth or creased on SubD compared to the mesh based approach:
subd_picture_frame_thicken.gh (35.7 KB)
@Joseph_Oster @HS_Kim Maybe you guys can help us! Please look into this query and guide us! Thanks in advance!
Hello @martinsiegrist , is there a way that I can morph a module in these Subd columns , you can see and get the module from the Gh script that I have posted!
