SubD bugs in Rhino 8
Hi all.
Reporting 2 minor bugs about SubDs.
  • 1
Toroidal SubD, 1 whole loop hard crease, 1 soft crease.
Moving one face result in wrong meshing near the vertex intersection from hard crease and soft crease:
2024-02-16 23_29_57-Window
sub crease meshing bug.3dm (146.5 KB)
EDIT:
this actually result in an open brep/surface after ToNurbs:
2024-02-17 00_14_32-Window
the surface has the same control points structure as if the soft crease didn’t exist.
  • 2
Toroidal SubD, 1 whole loop hard crease.
ToNurbs() output results in a single closed, periodic surface, as expected… but the seam is in a wrong place:
subd hard crease tonurbs seam bug.3dm (243.6 KB)
Iso-trimming a part of of the surface:
2024-02-16 23_37_04-Window
sharp without edge, quite odd…
Normally with SubDs I expect any hard crease to convert to a surface/brep edge after ToNurbs…
  • 3
    I take this occasion to ask once again for a manual SubD packing for ToNurbs feature.
Thanks for the support, have nice weekend.
Hi Riccardo - I see that on your example, I cannot reproduce it from scratch so far.
sub crease meshing bug 2
… @pascal were you able to replicate this?
…both?
My initial post is about 2 bugs, mainly…
Thanks.
@dalelear any ideas about this?
I can reproduce it here, odd thing is if you move one face the problem appears, BUT if you move a second face with the problem shown, then undo it, the problem disappears.
my soft crease is set to 90
I think I’ve fixed this bug and the fix will ship in 8.6.
I’ve added https://mcneel.myjetbrains.com/youtrack/issue/RH-80676 to make sure I test it.
It turns out https://mcneel.myjetbrains.com/youtrack/issue/RH-80676 is not fixed by the recent changes. This is a bug in the code that updates render meshes. The SubD itself is fine - only the mesh used to display it is bad. I’m working on fixing this bug now.
Hi Dale, thanks for the support.
With this
are you referring at the bug i’ve reported here?
Because it also applies to the brep/surface result of ToNurbs command:
Those control points ^ are of the brep/surface, not the SubD’s …
My guess is it is a problem somewhere before the meshing step.
But it’s just a guess from seeing from outside…
Output ToNurbs brep seems to be correct, but it’s only a “pulled” edge, if you launch _Explode and _RebuildEdges you can see the same defect in the actual surface.
(in the proposed steps to recreate the bug, instead of moving a face, extrude one, so you can easier explode the brep, do rebuildedges, see…)
Better than many words:
subd bug
The root cause of the gaps in ToNurbs and the display mesh were identical. Minutes ago I submitted a fix to our version control system. If the fix passes testing, it will ship in 8.6.
I apologize for the inconvenience. Thank your for taking the time to investigate this bug and provide such a clear reports of the problem.
Feb 29 UPDATE: I’ve tested this bug RH-80676 (and 3 related bugs RH-76871, RH-80633, and a report that has a model we cannot share publicly) in our daily internal release (8.6.24060.6001, 2024-02-29).
This problem and the related problems look like they are all fixed and the fixes will ship in 8.6.
works here in internal testing…I’m calling this fixed in 8.6
