Hi everyone! Plese teel me, is there ways to export subcategories from revit to rhino with grasshopper? I want to edit revit geometry in rhino. I already exported category - windows - but there comes on layer with glass, impost an so on. I want to export these separately.
I probably expressed myself incorrectly. I need to select the geometry of the subcategories (not the subcategories themselves) - frames separately, glass separately…
Just when I make boolean toggle true for subcategories choosing in query categories, i cant take geometry from it by this defenition. Which node should be used in this case so that the geometry is displayed correctly?
The geometry output matches the category in branching structure. Here is an example of using the categories to bake to layers.
Thanks a lot! Exactly what i need!
