Sub-object selection
I couldn´t be certain about this but with Sub-object selection checked shouldn´t draging a window from left to right select the sub-objects it covers? Right now I can only select individual objects by clicking but I would swear I could select sub-objects with window selection.
Please do correct me if I´m wrong,
Thank you
Window and crossing selections work as expected here with sub-object selection checked in the filter.
So this isn´t the expected behaviour?
Is there any hint at what might be causing this?
this is my systeminfo:
Rhino 7 SR28 2023-2-27 (Rhino 7, 7.28.23058.03001, Git hash:master @ 4ffc5d7156fbccf2a5d9fcc80e522b3851bc7f6c)
License type: Commercial, build 2023-02-27
License details: Cloud Zoo
Windows 11 (10.0.22621 SR0.0) or greater (Physical RAM: 16Gb)
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA Quadro P620 (NVidia) Memory: 2GB, Driver date: 6-6-2022 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 516.40
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 6-6-2022
Driver Version: 31.0.15.1640
Z-Buffer depth: 24 bits
Total Video Memory: 2 GB
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.28.23058.3001
C:\Program Files\Rhino 7\Plug-ins\AnimationTools.rhp “AnimationTools”
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.28.23058.3001
C:\Program Files\Rhino 7\Plug-ins\RhinoRender.rhp “Legacy Rhino Render”
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.28.23058.3001
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.28.23058.3001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.28.23058.3001
Hi @kral
Remember that it is not enough to turn on just sub-objects in the selection filter. You need to check mark which specific sub-objects (some or all of points/vertices, curves/edges, surfaces/faces); and remember that when you have the sub-object selection filter turned on, you don’t need to hold down ctrl+shift to select them.
HTH, Jakob
Seem alright on this front. Anything else I could be doing wrong? I mean … you can always reinstall but that´s kind of annoying.
Strange indeed! You cold try to update that graphics card driver - it’s a bit old and the card is a bit underpowered. Could be that a Windows update as messed something up.
HTH, Jakob
Righty´o. I´ll try stuff and see if stuff works. Anyway thanks for the input :slight_smile: It´s good to know it´s a problem on my side so I can fix it.
