Selection problem - not selecting all objects in
weird new glitch -
when i drag a selection rectangle from right to left to do a crossing selection,
or when i drag a selection rectangle from left to right to use a window selection,
all the objects in the rectangle are not selecting
how to fix this?
thanks
Hello - can you please send this file to tech@mcneel.com with a link back here in your comments? Also please run the SystemInfo command in Rhino and copy/paste the results here.
thank you - emailed the file here is system info:
Rhino 7 SR9 2021-8-10 (Rhino 7, 7.9.21222.15001, Git hash:master @ 190335c3fb65efe86c302714a8959a7dadfe667b)
License type: Commercial, build 2021-08-10
License details: Cloud Zoo
Windows 10.0.19043 SR0.0 or greater (Physical RAM: 32Gb)
Computer platform: DESKTOP
Primary display and OpenGL: Intel(R) UHD Graphics 630 (Intel) Memory: 1GB, Driver date: 9-5-2020 (M-D-Y). OpenGL Ver: 4.6.0 - Build 27.20.100.8681
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Vendor Name: Intel
Render version: 4.6
Shading Language: 4.60 - Build 27.20.100.8681
Driver Date: 9-5-2020
Driver Version: 27.20.100.8681
Z-Buffer depth: 24 bits
Total Video Memory: 1 GB
C:\Program Files\Rhino 7\Plug-ins\Tibidabo\Tibidabo.rhp “Tibidabo”
C:\Program Files\Rhino 7\Plug-ins\Tibidabo\VisualARQ.rhp “VisualARQ”
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.9.21222.15001
C:\Program Files\Rhino 7\Plug-ins\RPC.rhp “RPC”
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.9.21222.15001
C:\Program Files\Rhino 7\Plug-ins\RhinoRender.rhp “Legacy Rhino Render”
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.9.21222.15001
C:\Program Files\Rhino 7\Plug-ins\IronPython\RhinoDLR_Python.rhp “IronPython” 7.9.21222.15001
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.9.21222.15001
C:\Program Files\Rhino 7\Plug-ins\Grasshopper\GrasshopperPlugin.rhp “Grasshopper” 7.9.21222.15001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.9.21222.15001
Hello - see if disabling these two plug-ins in Options > Plug-ins page (then close and reopen Rhino), helps.
@daveed-kapoor - indeed, your file shows the selection problem if VA is loaded. I do not know enough about how VA works and interacts with the Rhino model to know if there is a legitimate reason for this…
yep disabling visual arq worked. thank you
Hi @daveed-kapoor,
This is how the “Hidden” display mode works, and this display mode is only available when you have VisualARQ installed.
This display mode ONLY selects what is visible, so if one curve is occluded by another curve, it is not selected. This allows working on plan and section views because, in Rhino, objects that are hidden by other objects can still be selected, and it makes it almost impossible to work on plan views.
Regards,
Enric
