I have a Rhino6 Educational License. It always worked fine, but recently it exhibits a strange behaviour. When I open Rhino I see all the views black. Then, when I click onto one of the view bars (e.g. on “Perspective”) all views become visibile (like they should by default upon opening Rhino) but I don’t switch to Perspective view. Then, if I click to another view bar (e.g. “Right”), I switch to perpective view, and so on: it seems that the command is received with a delay of exactly one command. Moreover I can’t even move or rotate any view (or rather, I can, but I see the effects only after clicking to a view tab). Same thing with most common commands to make lines and surfaces.
So the program still works, but it’s not functional to use it like this. Any idea?
Hello - the only thing that jumps out at me is the driver on your Intel is old - please update that driver, and the NVidia as well to the latest available from the Intel and NVidia websites, and see if that improves matters.
Hello - can you run SystemInfo again just so we can make sure Rhino sees the updated drivers, and can you please set a startup template file for Rhino that is not your usual one? Do this in Options > Files page. Does that change anything?
I am sorry Pascal but I made a complete Windows update and it seems suddenly working now. It was evidently an issue with the drivers.
Thanks a lot for your help.
