Hello, I’m a complete beginner with Rhino 8; could someone please help me with a question?
I have a scan of a part in STL format that I need to prepare for 3D printing. I want to make one of the outer faces completely flat, as the current outer surfaces are uneven; printing them as-is would require supports and a raft/base layer. I’d like to make one face—or at least a portion of it—perfectly flat to serve as the base for the initial print layers.
I’ve tried using the ShrinkWrap and QuadRemesh commands, but the model gets significantly distorted at the flat surfaces and corners.
Уголок рефрижератора.stl (2.5 MB)
