My document is still “edited” after I set the doc.Modified flag to false.
Version 8 (8.5.24072.13002, 2024-03-12)
Rhino Mac
import Rhino
doc = Rhino.RhinoDoc.ActiveDoc
doc.Modified = False
Rhino Mac
import Rhino
Hey @Johan_Lund_Pedersen,
In my brief testing, I’m not able to repeat this here.
Are you running any 3rd party plug-ins?
– Dale
Hi @dale
Thank you for getting back to me. I don’t think I have any plugins on the machine. My system info is below.
Am I right to assume that the code below should close Rhino without prompting to save?
Here is how it looks on my machine.
Also, the line Rhino.RhinoApp.Exit()
does not appear to do anything. I need to use RunScript
to get the “save as” response.
import Rhino
# Make a change to the doc
st = doc.Strings
st.SetString("change","doc")
Rhino.RhinoApp.Exit() # This line does not appear to do anything.
Rhino.RhinoApp.RunScript("Exit", False) # This line promotes the save as.
SystemInfo:
Rhino 8 SR5 2024-3-12 (Rhino 8, 8.5.24072.13002, Git hash:master @ e3530849b75f00b2b977766a567ae29b055837e9)
License type: Educational, build 2024-03-12
License details: Cloud Zoo
Apple macOS Version 14.4.1 (Build 23E224) (Physical RAM: 8GB)
Mac Model Identifier: iMac21,1
Language: en-DK (MacOS default)
.NET 7.0.0
Metal GPU Family Apple 7
Metal GPU Family Common 3
Metal GPU Family Mac 2
Graphics processors
Apple M1
iMac (2240 x 1260 @ 60.00Hz)
USB devices
Apple Inc.: Apple MagSafe Charger
Apple Inc.: Apple Watch Magnetic Charging Cable
USB: SanDisk 3.2Gen1
Bluetooth devices
None
Third party kernel extensions
None
Third party plugins
/usr/lib/usd/libusd_ms.dylib
/usr/lib/swift/libswiftCoreML.dylib
/usr/lib/swift/libswiftFileProvider.dylib
/usr/lib/swift/libswiftGLKit.dylib
/usr/lib/swift/libswiftGameplayKit.dylib
/usr/lib/swift/libswiftMetalKit.dylib
/usr/lib/swift/libswiftModelIO.dylib
/usr/lib/swift/libswiftSceneKit.dylib
/usr/lib/swift/libswiftSpriteKit.dylib
/usr/lib/swift/libswiftVision.dylib
/usr/lib/swift/libswiftShazamKit.dylib
/usr/lib/swift/libswiftObservation.dylib
/usr/lib/swift/libswiftVideoToolbox.dylib
/usr/lib/swift/libswiftWebKit.dylib
/usr/lib/swift/libswiftNaturalLanguage.dylib
/usr/lib/swift/libswiftMapKit.dylib
/Users/johanpedersen/.rhinocode/py39-rh8/libpython3.9.dylib
/Users/johanpedersen/.rhinocode/py39-rh8/lib/python3.9/lib-dynload/_heapq.cpython-39-darwin.so
/Applications/Rhino 8.app/Contents/Frameworks/RhMaterialEditor.framework “Renderer Development Kit” 8.5.24072.1002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Commands.rhp “Commands” 8.5.24072.13002
/Applications/Rhino 8.app/Contents/PlugIns/NamedSnapshots.rhp “Snapshots” 8.5.24072.1002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCodePlugin.rhp “RhinoCodePlugin” 8.5.24072.13002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RDK_EtoUI.rhp “RDK_EtoUI” 8.5.24072.13002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/MeshCommands.rhp “MeshCommands” 8.5.24072.13002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoRenderCycles.rhp “Rhino Render” 8.5.24072.13002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCycles.rhp “RhinoCycles” 8.5.24072.13002
/Applications/Rhino 8.app/Contents/PlugIns/SectionTools.rhp “SectionTools” 8.5.24072.1002
/Applications/Rhino 8.app/Contents/PlugIns/Displacement.rhp “Displacement” 8.5.24072.1002
/Applications/Rhino 8.app/Contents/PlugIns/PanelingTools.rhp “PanelingTools” 8.5.24072.1002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoDLR_Python.rhp “IronPython” 8.5.24072.13002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/GrasshopperPlugin.rhp “Grasshopper” 8.5.24072.13002
Sorry for the delay in replying.
Setting the RhinoDoc.Modified
flag in Rhino for Mac currently does nothing. This is because, unlike Windows, Mac document changes are managed by the operating system. For now, the best you can do is look to see if the document is modified and take whatever action you need.
Not sure why this isn’t document…
– Dale
Hi Dan
Thank you for your relay.
Am I right to assume that my options then are:
dispose()
of the docI think that it would be nice if there was a way to exit without saving from the command line.
Something like “-Exit ExitWithoutSaveing”
