Standard deviation?
As stated by David in his Unpublished opinion piece : " A computer can calculate the standard deviation of a million numbers before your finger has had time to let go of the Enter key."
… yet I can find no trace of this useful function in GH or in any of the plugins I researched.
Am I missing something obvious ?
Hi Olivier,
What would you use the standard deviation for in Rhino?
Honest question.
-Willem
PointDeviation reports standard deviation. I’ve used it to judge the quality of the overall fit, not just the maximum deviation.
Hi Willem,
I want to use galapagos to minimize the standard deviation of the spacings between objects, depending on a bunch of parameters.
You will find many components on G2
Meanwhile you can use MathNet that has many statistics function (this library is also used in G2)
I also used it a lot on my old work, as all parameters in my models were not a single number but a distribution model (mean + standard deviation for example).
  /// <summary>
        /// Calcule l'écart type d'un ensemble de valeurs connaissant la moyenne (division par n-1 au lieu de n)
        /// </summary>
        /// <param name="arg_lst_values">Liste ou tableau de valeurs</param>
        /// <param name="arg_mean">Moyenne arithmétique</param>
        /// <returns></returns>
        public static double StandardDeviationUnbiased(IEnumerable<double> arg_lst_values, double arg_mean)
            double standardDeviation = 0;
            int number = 0;
            foreach (double val in arg_lst_values)
                if (!double.IsNaN(val))
                    standardDeviation += (val - arg_mean) * (val - arg_mean);
                    number++;
            if (number > 1)
                standardDeviation = Math.Sqrt(standardDeviation / ((double)number - 1.0));
            return standardDeviation;
I looked for math functions in Nautilus of course, but what’s G2 ?
Grasshopper 2 :eyes:
Maybe not exactly obvious, but it does the trick natively in Grasshopper 1: The standard Python library has a statistics module, which has a standard deviation function (and other useful functions):
250521_StandardDeviation_00.gh (6.8 KB)
For more fancy stuff, the new CPython editor in Rhino 8 supports e.g. numpy.
Yes, though I encountered a weird progressive slowdown condition using it a couple years ago:
Of course, searching the forum is always a good idea:
https://discourse.mcneel.com/search?q=standard%20deviation
I can’t seem to replicate the progressive slowdown, but @nathanletwory’s implementation of the variance function is still way faster than the standard library version! That’s good to know, thanks.
250521_StandardDeviation_01.gh (8.5 KB)
Hi Luis ! :slightly_smiling_face:
:man_facepalming: of course, GH2 !
Yes Grasshopper 2, G2 is the command to launch Grasshopper 2 . I understand it was not very useful but it shows that some parts will be better covered by Grasshopper 2 (Field, statistics, functions …)
with the C# function
250521_StandardDeviation_02.gh (11.9 KB)
Looks like it’s just the IronPython implementation that’s much slower. The standard CPython implementation is on par with @laurent_delrieu’s C# script. But then again the CPython component comes with a potential input cost on large data sets:
250522_StandardDeviation_00.gh (15.7 KB)
Just tried this. If we disregard the cost of inputting large lists, the numpy function calls are basically free:
250522_StandardDeviation_01.gh (13.4 KB)
