In the lastest sr Version 7 SR9 (7.9.21222.15001, 2021-08-10)
I am now getting incomplete drawing of closed curve linework in the viewport. Doesn’t matter if I’m in wireframe or shaded or a custom view mode. Closed curves are not completely drawn until I zoom in and some are drawn closed while others are not. This can play havoc when you need closed curves and zoom out and you see random ones are not closed. I know these are all closed curves as I ran the selclosed curves command on them and when I zoom in they close up and redraw properly. This wasn’t happening in the last sr.
Rhino 7 SR9 2021-8-10 (Rhino 7, 7.9.21222.15001,
License type: Commercial, build 2021-08-10
Windows 10.0.19043 SR0.0 or greater (Physical RAM: 32Gb)
Computer platform: LAPTOP - Plugged in [95% battery remaining]
Primary display: Intel(R) HD Graphics 530 (Intel) Memory: 1GB, Driver date: 11-18-2018 (M-D-Y).
- Windows Main Display attached to adapter port #1
Primary OpenGL: NVIDIA GeForce GTX 960M (NVidia) Memory: 4GB, Driver date: 9-30-2020 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 456.71
> Integrated accelerated graphics device (shares primary device ports)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 8x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 9-30-2020
Driver Version: 27.21.14.5671
Z-Buffer depth: 24 bits
Total Video Memory: 4 GB
E:\rhino3d\BoltGen\BoltGen1_62.rhp “BoltGen” 0.0.0.0
E:\Downloads\elefront411\ElefrontProperties.rhp “ElefrontProperties” 1.0.0.0
C:\Program Files\Common Files\McNeel\Rhinoceros\6.0\Plug-ins\WebCam (b03d9978-150a-4297-95e0-d8a50df7c0b0)\1.0.0.0\WebCam.rhp “WebCam” 1.0.0.0
C:\ProgramData\McNeel\Rhinoceros\7.0\Plug-ins\Twinmotion Direct Link 2020.2 (e24ee14a-9514-47da-8fe6-f6e61b20160e)\Twinmotion Direct Link 2020.rhp “Twinmotion Direct Link 2020” 1.0.6.0
C:\Users\User\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\NVIDIADenoiser\0.4.0\NVIDIADenoiser.Windows.rhp “NVIDIADenoiser.Windows” 0.4.0.0
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.9.21222.15001
C:\Program Files\Rhino 7\Plug-ins\RhinoScript.rhp “RhinoScript”
C:\Program Files\Rhino 7\Plug-ins\RPC.rhp “RPC”
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.9.21222.15001
C:\Program Files\Rhino 7\Plug-ins\RhinoRender.rhp “Legacy Rhino Render”
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.9.21222.15001
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.9.21222.15001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.9.21222.15001
C:\Program Files\Rhino 7\Plug-ins\Calc.rhp “Calc”
C:\Users\User\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\PanelingTools\2020.9.1.565\PanelingTools.rhp “PanelingTools”
C:\Users\User\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\SectionTools\2020.12.7.446\SectionTools.rhp “SectionTools”
RM
