Curve drawing issues
Rhino 8 has been working normally then for some reason i can’t even draw a line.PersistentClose=No Close Mode=Line Helpers=No Length Undo and this keep popping up.what should I do?
@kkksd what keeps popping up? is there an error message that didn’t get attached?
Next point of polyline. Press Enter when done ( PersistentClose=No Close Mode=Line Helpers=No Length Undo )
Here is the whole message.
what happens when you press enter?
the process, is click for a start and end point, repeat as needed, then hit enter or right click your mouse.
I press enter and everything dissapears
I can’t draw lines,circles,points.It was working like three days ago.I don’t know what to do,I have exam on Monday :frowning:
Run the Rhino command SystemInfo and post the results.
Rhino 8 SR14 2024-12-10 (Rhino 8, 8.14.24345.15001, Git hash:master @ cdb74b46090a23fe242c51b288886f76467a741b)
License type: Evaluation, build 2024-12-10
License details: Cloud Zoo
Expires on: 2025-03-05
Windows 11 (10.0.22631 SR0.0) or greater (Physical RAM: 8GB)
.NET 7.0.0
Primary display and OpenGL: Intel(R) Iris(R) Xe Graphics (Intel) Memory: 128MB, Driver date: 7-1-2024 (M-D-Y). OpenGL Ver: 4.6.0 - Build 31.0.101.5522
Primary OpenGL: Intel(R) Iris(R) Xe Graphics (Intel) Memory: 128MB, Driver date: 7-1-2024 (M-D-Y). OpenGL Ver: 4.6.0 - Build 31.0.101.5522
> Integrated (slow!) graphics device with 4 adapter port(s)
OpenGL Settings
Safe mode: Off
GPU Tessellation is: On
Anti-alias mode: 4x
Mip Map Filtering: Linear
Vendor Name: Intel
Render version: 4.6
Shading Language: 4.60 - Build 31.0.101.5522
Driver Date: 7-1-2024
Driver Version: 31.0.101.5522
Z-Buffer depth: 24 bits
Total Video Memory: 128 MB
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.14.24345.15001
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.14.24345.15001
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.14.24345.15001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.14.24345.15001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.14.24345.15001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.14.24345.15001
I don’t know how you can run Rhino with a 128 megabyte (not gigabyte) graphics card…? Surprised it opens at all. Or something is very wrong with the SystemInfo report.
I just checked,SystemInfo is wrong.
Try turning tessellation off. Intel GPUs have had problems with this feature. Open the options dialog and go to the OpenGL settings under View and uncheck GPU Tessellation
I still can’t draw lines, what should I do?
Is there another graphics card in your system? That doesn’t show up in SystemInfo?
Total available graphics memory:4115 MB
OK, I would try downloading and reinstalling the driver of your main graphics card, it appears to be corrupt or missing (doesn’t show up in SystemInfo).
Just tried that,it doesn’t work.
Does the video driver now show up correctly in SystemInfo? If not there is still something wrong. What does the device manager say about your video card?
Also @kkksd what video card is in your system. If it is an Nvidia card make sure to do a clean install
Dedicated video memory:128MB.
But program seems fine except some basic comands like line or points.
@kkksd ok, so there is only the intel graphics in your system?
Keep in mind that the minimum requirement to run Rhino 8 is a graphics card with at least 4Gb of video memory.
