OK _ I’m able to repeat the word “Command” being repeated the the command line, but it appears to be a cosmetic issue. The command still executes, and the view is saved.
I find it a bit hard lately to keep track of which SR I’m running. Sometimes there are 2 updates a day. I didn’t use Rhino yesterday but I’m rather sure it was working on Monday.
Just to confirm your work flow: from within the NamedViews panel you save a named view called ‘v1’. You then mess with the view. Then you enter ‘v1’ from the command line and you get “unknown command”.
Hi @dale,
That’s correct, yes. My template file includes 2 named views (v0 and v1) - Rhino 6 and Rhino 7 WIP open up with this same custom template. In the WIP (RH7, that is), entering ‘v0’ and ‘v1’ will update the view (as does RH5 and did RH6 up until last week) - in the current RH6 RC3 WIP, this echoes “unknow command”.
-w
