Hi
I am some how confused in the difference between unroll surface and squish commands.
I want to flatten these strips for laser cut using flexible foam.
Should I use squish or unroll surface ?
Hello - use UnrollSrf if it accepts the objects and gives a result, otherwise you may need Squish - please see Help on these commands for more info.
https://docs.mcneel.com/rhino/6/help/en-us/commands/unrollsrf.htm
https://docs.mcneel.com/rhino/6/help/en-us/commands/squish.htm
