Hi everyone,
I ask you for advice how to split this surface to rhombic pieces. I need each piece with the same size.
I’m still beginner and I really appreciate your help.
Thanks Pavel
Hi everyone,
Thanks Pavel
I’d suggest Paneling Tools for this which can be installed as a plugin or used in Grasshopper… more info here
https://wiki.mcneel.com/labs/panelingtools
You asked a simple question to which only complexity answers. You are asking for a unitized system on a rather free-form surface. The nature of the surface matters greatly. Also you’ll need to define your rhombuses. Are they flat? If so, expect huge gaps between them.
My suggestion is that you look into surface tessellation just a little more and possibly refine your question so it’s a little less generic
See if you can get anything out of this scriptforum-rhompanel.gh (8.0 KB) Open it on the file you provided.
Thank you Brian.
I solved with Paneling Tools.
