Splitting a brep with curves
hello guys i have been trying to trim holes of a brep with the boundary curves of these holes i coudnt do it any hellp please? kinda urgent for school project
pronlem soutraitance.gh (20.6 KB)
Please internalize goemetry
i cant because the file is 66 mb>20 maximum
Use “Trim Solid” instead of “Brep | Brep” intersector.
2022-05-05 20_36_26-Window
If your breps are closed, it should work fine…
it says failed from to brep to curves
At least tell us which grometry or internalize the curves points and will apply on a solid sphere.
It is not that magical to make intersections and call it away, you need to consider the below:
1- Intersecting meshes are much faster and predictable, but make sure you are running clean and welded mesh prior.
2- the outcome from intersection may result in self intersecting curves, please offset, close and rebuild as necessary otherwise your surface splitting won’t work.
3- Keep an eye on the performance vs accuracy. I decided to rebuild the outcome of the intersection with degree 5 to get rid of surface kinks.
4- use more pufferfish.
pronlem soutraitance.gh (18.6 KB)
