Hi there,
I am unable to find the command SplitMeshWithCurve in both rhinoscript and Rhino app. And also more basic commands and advanced commands operating with meshes (cutting, trimming, intersecting…) Where should I look to find them ?
Thanks !
Hi there,
Thanks !
Hi Peter,
The usual process for splitting a mesh with a curve is to first extrude the curve through the mesh. Then create a mesh from the extrusion. And finally using this mesh as the cutter.
Does this help?
– Dale
Hi Dale,
sure, this helps perfectly ! Browsing the available commands I have found MeshMeshAccurate, MeshMeshFast and Mesh.Split. Is there any fundamental difference between these commands or some additional contraints? I would like to do exactly what SplitMeshWithCurve command is doing. Which one would you prefer ?
Peter
Hi Peter,
The Rhino.Geometry.Intersect.MeshMeshAccurate
and Rhino.Geometry.Intersect.MeshMeshFast
static functions only calculate the intersection between two meshes. They will not split a mesh.
Use Rhino.Geometry.Mesh.Split
– Dale
Yes, you are right. Thanks Dale !
Peter
