I’m looking to take a full size contour plate and split/panelize using GH, and then bring the geometry back to Tekla. While there is a cut tool, this causes issues since I want to keep geometry on both sides of the cut. Is there a GH component that can mimic the “split” Tekla tool?
I know the search tools are not broken so I guess your and @osuire just don’t know how to use them. ![]()
No i’ve tried this, and from what I’ve seen it does not mimic the “split” tool in Tekla. I know there is not a split tool in the Tekla GH plugin, but I’m hoping there is a C# script option.
Do you use Tekla Joseph?
I believe I addressed this issue in one of your earlier threads. Sorry you missed it.
These achieve the desired result operating on breps in Rhino, but not when trying to modify geometry/model objects (contour plate) within the Tekla model.
@sebastian.lindholm do you know of any solutions to create a “split” component for contour plates?
Hi Forrest,
There’s a thread here about splitting a beam:
I’m sure some of the proposals could be adapted to work for plates as well. You would just work with the deconstructed boundary of the plate instead of the beam centerline.
Cheers,
-b
