Hey, I’m trying to make a split bar from grasshopper for tekla. I’ve seen some videos about it but they use C# code. There is another way to make it?
Thanks!
Thanks!
Hi, if you would be open to using code you should be able to use the Split() command as in this thread:
Note that there are some limitations if used through the Grasshopper Component in Tekla.
Without code, you might be able to create your own splitter with something like this approach:
Cheers,
Sebastian
Jennifer Rojas reacted to your message:
It worked.
Thanks!
