Split surface still protrudes
when i split a surface against the other and delete the unwanted parts, the split surface still shows through the other. What am i doing wrong?split srf.3dm (123.8 KB)
Hello Scott, you are not doing anything wrong. You just need to adjust your render mesh under tools- options.
Thanks Tone,
Why was that the case?
Cheers
because usually the render mesh has low resolution to improve the workflow and avoid lagging or delays while paninf or rotating the views, specially in large files.
