split file.3dm (77.2 KB)
Hi Forum, Here is about a 17" surface that I want to split. It does split ,but the graphic looks off where the split is . Any way to know it is accurate? It is the same in both V7 and V8. To clarify, I am using the large surface to split the small one. Thanks to anyone who wants to help.—Mark
Hello- do you mean it looks incorrect in a shaded view or that the split is not accurate? The larger surface has a very sparse display mesh which will not hit the edges of the split surface.
I see that now . I upped the mesh setting and it hit the line more close. Solved then .Thank you Pascal
