Split or Trim a Mesh
Hello Everyone
I received a mesh model of a friend and we want to split or trim it, But we couldn’t do this step
This mesh was generated with commnand ApplyDisplacement.
So I suggested him to split the surface before using ExtractRenderMesh
However I want to solve this problem to separe it :slight_smile: (of course I used Boolean mesh tools)
Thanks for your help
Hi Jesus - that is a hard one - what I’d do here is Mesh the surface, then MeshIntersect then SplitMeshWithCurve - that does seem to get the right answer in this case.
Hi Pascal
Thanks as always by your help (I didn’t know this command :). as always I have still too much to learn)
One day I’ll write a better challenge :slight_smile:
Thanks again
best regards
As I understand it you wish to split the mesh using the surface. I was able to do this using the following workflow:-
Extrude the surface into a solid larger than the top half of the mesh.
Convert the resulting polysurface into a mesh (_Mesh). Hide or delete the polysurface.
You can now use this new mesh object to split your mesh using the _meshsplit command
General tip when it comes to splitting a mesh. It sometimes help to move or rotate the object before spliting.
Best,
MarkCK
