I want to trim this object by the plane so that I have a flat surface. the first plane which was on the top worked fine but the bottom one doesn’t work. Can you please suggest why this happening.
Thanks
Thanks
Your have a few polysurfaces which are not joined. If you select all surfaces and join them together, then split will work.
I tried but it doesn’t work. I even exploded and join them again but not working.
The inner surface gets cut but not the outer surface.
