Unable to Split Closed Polysurface with line
PeriscopeSplitForum.3dm (1.4 MB)
I am trying to split the two closed polysurfaces with the line (in the file). It only splits the top polysurface and not the bottom one. How can I fix this?
Thanks,
Ilan
dear @Ilan_Farahi
i am not 100% sure but I would guess:
There are some surfaces that are (nearly) coplanar / or (nearly) overlapping to the cutting-profile. Maybe also some issues regarding tangential constellations.
same for some edges.
additionally there is a very tiny surface (x).
regardless of the error:
_extrudeCrv (your cutting-profile, blue surface in screenshot)
_explode
… sort all surfaces that don t need to be split to different layers.
_trim or _split each single surface
_join …
if you want to figure out which part of the polysurface is responsible for the error
_extractSrf one by one and try split…
Thank you, Tom! That helped a lot.
