Split a solid object with just curves
Is there an option for split a solid object with just curves like these:
Curveboolean,split and booleandifference not work for this situation
Try _Wirecut… But you are only limited to one cutting curve at a time.
Otherwise, Extrude (use the Gumball vertical extrusion handle) then BooleanSplit.
Thank you, tried wirecut but fastest way is extrude then BooleanSplit as you said
Well, I have this for a Wirecut macro under an alias “wc”
! _Wirecut _Pause _Pause Direction=CPlaneNormal _DeleteInput=_No _BothSides=_No _KeepAll=_Yes _Enter
Which makes it a two click solution for splitting a single object (you need to be in a view where the CPlane is perpendicular to the cut direction)
Sorry but i can’t do it. I Added your macro to aliases section , what can i do after that? Is this top view correct:
One curve at a time…
Ahh right, sorry
