I have to do this action a lot. Whats the best way to do this?
The method I currently use takes quite a few steps:
1- draw cutting line
2- split command
3- join curves of left side
4- redraw cutting line on right side
5- join right side
You can use CurveBoolean its very simple but you have to change all the horrible default options to this.
DeleteInput=All CombineRegions=No Output=Curves AllRegions
If you like the way you currently do it but want to speed it up you can do that as well…
1- draw cutting line (select it and CTRL+C to copy it)
2- split command
4- CTRL+V to paste your curve (no need to draw it over and over just copy paste!)
5- join right side
Thats actually the method I already use. But whenever I need to use copy/paste like that, it just feels sloppy to me… I’m always looking to improve whatever I’m doing
