Spell check stopped working
Can anyone tell me why my R6 spell check might have stopped working?
It worked for a couple of days after the service release.
I am up to date and do have the latest version of Rhino.
thanks
It spell check turned on in Windows 10?
Run Settings > Devices > Typing
Hi John
My settings seem to be correct
If you run the Rhino text annotation tool and type “Rhinaceros”, is it underlined indicating it is misspelled?
Hi John
It seems to be working on the Rhino annotation tool but not when I type info into leaders.
I’m not sure if this is related but since yesterday I have started having issues with dimensions not working properly and then noticed the following message when I start Rhino:
Message: Could not load type ‘Rhino.DocObjects.DimensionStyleArrowType’ from assembly ‘RhinoCommon, Version=6.9.18271.20591, Culture=neutral, PublicKeyToken=552281e97c755530’.
Blocking plug-in KeyShot7RhinoPlugin.
Blocking plug-in ElefrontProperties.
Blocking plug-in EvoluteCoutHook.
Tibidabo 18.11 loaded.
VisualARQ: Loaded (2.3 SR2, Build 12744, 2018/10/11).
VisualARQ: License OK.
Loading Rhino Render, version 1.50, Sep 28 2018, 21:43:56
File “C:\Users\SEAN\AppData\Roaming\McNeel\Rhinoceros\6.0\UI\VisualARQ2.rui” is already open.
An error occured during GHA assembly loading:
Path: C:\Users\SEAN\AppData\Roaming\Grasshopper\Libraries\Panda_GH_R5.gha
Exception System.TypeLoadException:
I’m getting the underscore in the leader dialog after I type a space behind the misspelled word.
This will need a developer to chase down the RhinoCommon error.
Hi John
So my bad Rhinaceros does get highlighted but not much else. See below
On an outside chance, try a more basic, standard font like Arial
Any different?
That worked! Wow good call.
Any opinion on my Dimension message issue Message: Could not load type ‘Rhino.DocObjects.DimensionStyleArrowType’ from assembly ‘RhinoCommon, Version=6.9.18271.20591, Culture=neutral, PublicKeyToken=552281e97c755530’.
What was the other font you were using?
Can you send us a copy of the TTF/OTF font file?
Ok Its called architex its obscure. Where can I mail it it wont upload.
Send it to tech@mcneel.com and include this URL in the message:
Thanks
Do you also get that when you start Rhino in safe mode?
Word has it that this is probably caused by a plug-in that was written for Rhino 5. If you are not getting this in safe mode, try to disable plug-ins until you find the one that is causing that.
This may be coming from the panda component. I just looked at food4rhino and there is a V6 version of this component that you may want to be using.
Hi Steve
It was the font I was using. Rhino couldn’t read it as it was quite obscure.
Hi Sean,
Steve was referring to the 2nd problem you reported.
Oh great. Ill update as soon as its released I had the same problem again yesterday! Thanks
