Spacemouse Unresponsive in Rhino 8
Hi all,
I’ve recently installed Rhino 8 (evaluation) and have found that the my spacemouse ‘handle’ is unresponsive.
The buttons work, but not the knob. Anyone have any tips?
Thank you!
Brian
Did you plug in your spacemouse before starting Rhino? Does it function correctly in a previous version of Rhino?
Pls run _SystemInfo in Rhino and post back the results.
Yes, it works perfectly in Rhino 7, Yes, I plugged it it before starting Rhino 8. The buttons work fine, only the handle doesn’t.
Rhino 8 SR0 2023-10-31 (Rhino 8, 8.0.23304.09001, Git hash:master @ 20e15cf9bd66e6676f849f22e485cb3e82a8beac)
License type: Evaluation, build 2023-10-31
License details: Cloud Zoo
Expires on: 2024-02-08
Windows 10 (10.0.19045 SR0.0) or greater (Physical RAM: 32Gb)
.NET 7.0.0
Primary display and OpenGL: NVIDIA GeForce RTX 2070 Super (NVidia) Memory: 8GB, Driver date: 10-11-2023 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 545.84
Primary OpenGL: NVIDIA GeForce RTX 2070 Super (NVidia) Memory: 8GB, Driver date: 10-11-2023 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 545.84
Secondary graphics devices.
Intel(R) UHD Graphics 630 (Intel) Memory: 1GB, Driver date: 6-1-2021 (M-D-Y).
- There are no monitors attached to this device. Laptop lid is probably closed
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 10-11-2023
Driver Version: 31.0.15.4584
Z-Buffer depth: 24 bits
Total Video Memory: 8 GB
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.0.23304.9001
C:\Program Files\Rhino 8\Plug-ins\AnimationTools.rhp “AnimationTools”
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.0.23304.9001
C:\Program Files\Rhino 8\Plug-ins\RhinoRender.rhp “Legacy Rhino Render”
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.0.23304.9001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.0.23304.9001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.0.23304.9001
C:\Program Files\Rhino 8\Plug-ins\RhinoCode\RhinoCodePlugin.rhp “RhinoCodePlugin” 8.0.23304.9001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.0.23304.9001
could it be that these got unchecked accidentally:
where is that menu?
I have a button on the spacemouse that opens it, not sure how else to access it
I see, the menu key on the spacemouse. Nope all boxes are checked
Just to be sure, you did not install any spacemouse software or drivers? The spacemouse should work in Rhino right away.
Other than that, I would try to run a Rhino repair (not reinstall) to see if that solves it.
One other thing: did you restart your pc in the meantime? Sometimes odd problems solve by a restart.
I have issues with the spacemouse not waking when Rhino is started. Mouse is fine. I have to unplug and plug in to wake it up. This ONLY happens with Rhino.
Hi Dale,
Is your 3DConnexion SpaceMouse driver up to date? Current release for Windows is 10.8.16.
Regards
Jeremy
Updating my spacemouse driver did the trick, Thanks!
@Brian_D_Slack good to hear that has solve it for you.
@jeremy5 thanks, I never thought of that, since I never installed any driver for mine.
