Sometimes I cannot pick the polycurve by ExtractSubcurve Command
Sometimes I cannot select the polycurve by ExtractSubcurve Command .
When I encounterd this, I use Explode command, then Join command , after that, I can select it.
That was not good very much , for time consuming.
Hi Katsu- please post an example of this and we can take a look. You might also try SimplifyCrv when ExtractSubCrv fails and see if that works any better.
thanks,
Hi, pascal. Thanks.
I attached the file that contains only one Polycurve.
ExtractSubCrv does not work well to this polycurve.
But it does work well after SimplifyCrv or Explode-and-Join.
ExtractSubCrv.3dm (48.3 KB)
Hi Katsu- Rhino does not see that as a polycurve- use the What command to check it - until SimplifyCrv is run in it,
Hi Pascal,
Thanks, I understood.
But how about In ExtractSubCurve command , Copy the polycurve , SimplifyCrv it internally if it is necessary?
