Hi @simon9
This seems to have been fixed/changed for V8, although I’d wish for the copy=yes/no and join=yes/no switches to be scriptable even with pre-selected sub-objects, exposing them together with the “Select polycurve for subcurve extraction” prompt.
For now you have to:
Run the command with no pre-selection
Select a curve to extract segments from
Set your switches
Select at least one segment
Complete the command
Undo…
just to make the switches stick with pre-selected sub-objects
And if you set the switches to copy=yes and join=yes, as you complete the command with pre-selected sub-objects, both the original segments and the resulting copy are selected. Surely that’s not the intended behaviour?
Actually I never really understood why you have to select a curve to extract the segments from? Why cant we just select segments from any given polyline/polycurve, in stead of limiting the selection to one single entity?
Seems like the command could do with a tune-up, no?
I am still using Rhino 6. I also think it would make sense to be able to pre-select any given number of segments and then run the ExtractSubCurve command.
