Something problem about import sketchup object & mapping on rhino 7
Rhino 7 SR2 2021-1-21 (Rhino 7, 7.2.21021.07001,
License type: 商業版, build 2021-01-21
License details: Cloud Zoo
Windows 10.0.19041 SR0.0 or greater (Physical RAM: 16Gb)
Running on a virtual machine: VMware Virtual Platform
Computer platform: DESKTOP
Primary display: VMware SVGA 3D (VMware, Inc.) Memory: 0MB, Driver date: 10-18-2019 (M-D-Y).
> External USB display device with 8 adapter port(s)
Primary OpenGL: SVGA3D; build: RELEASE; LLVM;: VMware, Inc… OpenGL Ver: 3.3 (Compatibility Profile) Mesa 19.1.0 (git-cee1f21471)
> No graphics device is being used for OpenGL
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
No one have a same problem?
Your virtual machine is not supported platform
Not supported
  • Windows 8 and older
  • Windows Server (any version)
  • Boot Camp on Apple Silicon. M1 Macs.
  • Virtualization systems such as VMWare, Remote Desktop, and Parallels
  • Linux
  • ARM processors including the Microsoft SQ® 1 and 2
    Rhino - System Requirements
There is the same problem on windows 8.1, not on vmware
License type: Commercial, build 2021-01-21
Windows (Physical RAM: 7.9Gb)
VersionMajorMinorServicePack failed
Computer platform: LAPTOP - Unplugged [96% battery remaining] ~238 minutes left
Primary display and OpenGL: Intel(R) HD Graphics 4600 (Intel) Memory: 2GB, Driver date: 3-30-2014 (M-D-Y). OpenGL Ver: 4.4.0
Secondary graphics devices.
NVIDIA GeForce GT 750M (NVidia) Memory: 2GB, Driver date: 7-2-2014 (M-D-Y).
> Integrated acclerated graphics device (shares primary device ports)
- This device is not being used
ATTENTION:
No graphics device is being used. Either an error occurred on startup, or certain devices have been disabled.
See below for any possible configuration changes that may help resolve this issue.
  • Any hardware configuration or cabling changes you make will require that you restart Rhino.
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Render version: 4.4
Shading Language: 4.40 NVIDIA via Cg compiler
Driver Date: 7-2-2014
Driver Version: 9.18.13.4052
Z-Buffer depth: 24 bits
Total Video Memory: 2 GB
Any idea to make good it?
Hello - your video drivers are ~7 years old - the first thing to do is update these to the most recent available from Nvidia’s and Intel’s websites. It looks like you need a Windows update as well.
This problem isn’t on the display driver , window update on vmware platform!
There is a problem of sketchup importer, because I use this file open on sketchup, and then export to fbx file, the 3d model import normal.
I will try the problem of apply custom mapping, they are sure it should work done?
Hi @l1407
Could you upload your Sketchup file, please? If you want to keep it private you can use this upload link: Rhino - Upload to Support
Hi @l1407 Thanks for the file. I can import it correctly in Rhino 7.4.21036 using these settings:
If I enable Weld Angle then texture shows up incorrectly like in your screen capture.
Could you explain why you’re applying that custom mapping?
Hello, I actually have this situation. But I’m in a dilemma. When I select “Weld Angle” this happens with the texture, but when I remove the Weld Angle, the final geometry in sketchup has visible lines. If I send the model back to my client who uses Sketchup, he will complain. Is there a way to use the “Weld Angle” without messing up the faces?
Here’s a sample file:
ImportSKP.skp (2.7 MB)
I need to import this in Rhino, model other things, then export to SKP again for my client.
And need the objets to return smooth as they were when he sent me. How do I do this? :confused:
This is the config I use to make it smooth, but bugged.
@Jussi_Aaltonen help pls :smiley:
Actually it’s Weld angle and JoinFaces together.
I’m looking at the toilet seats. It looks like their texture UV’s are discontinuous over almost every edge on the mesh. So doing any welding in Rhino is going to affect the UV’s.
The issue seems to be in the SKP export. It modifies the mesh normals making it look faceted instead of smooth.
In general opening and saving an SKP file in Rhino is likely to modify the model in some way because it first gets converted into a Rhino model and then back to an SKP file.
RH-86616 Sketchup export: modifies mesh normals
Hi. What does this youtrack link means? I usualy see those links on the forum but never got it. Does this mean that the bug is being worked on?
It simply means that the linked YT bug track item is created for the issue reported here. Usually the YT bug track item has a link back to the discourse thread.
I looked at the issue you reported and filed that YT item. Based on the comments there I might need to do some further investigatation before it can be fixed.
