Some commands are not working in rhino tools installed in Rhino 6
I just installed section tools in rhino 6. I have created a section and also projected it into a layout via Create Sections 2D layout. The thing is that Clear one section from view and Clear All sections from views commands are not working. I am getting unknown command. The result is that I cannot delete the remaining section layout. What is going wrong?
Thanks in advance!
Is the plug-in Loaded and Enabled?
Also, please run the Rhino command SystemInfo and post the result here.
Hello - can you please run the SystemInfo command (Help menu > System information) and copy/paste the output here?
I really appreciate your immediate responses. I apologize for not replying earlier.
@wim , Yes I believe that it is already loaded and enabled, otherwise I could not even use one of the commands available. Am I right?
@pascal , I am giving the result of the SystemInfo command below.
Rhino 6 SR6
Windows 10.0 SR0.0 or greater (Physical RAM: 7.9Gb)
GeForce GTX 850M/PCIe/SSE2 (OpenGL ver:4.6.0 NVIDIA 398.82)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 8x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 7-30-2018
Driver Version: 24.21.13.9882
Z-Buffer depth: 24 bits
Total Video Memory: 4 GB
C:\Program Files\Rhino 6\Plug-ins\Commands.rhp “Commands” 6.6.18177.16151
C:\Program Files\Rhino 6\Plug-ins\Tibidabo\Tibidabo.rhp “Tibidabo”
C:\Program Files\Rhino 6\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 6.6.18177.16151
C:\Program Files\Rhino 6\Plug-ins\RhinoCycles.rhp “RhinoCycles” 6.6.18177.16151
C:\Program Files\Rhino 6\Plug-ins\Tibidabo\Lands.rhp “Lands Design”
C:\Program Files\Rhino 6\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 6.6.18177.16151
C:\Users\acer\AppData\Roaming\McNeel\Rhinoceros\6.0\Plug-ins\OctaneRenderForRhino (f109bd23-4cf3-4c0b-9f83-06be474b0152)\3.8.0.91\RHI Installer 6\Rhino 6.0\x64\OctaneRenderForRhino.rhp “OctaneRenderForRhino” 3.8.0.91
C:\Program Files\Common Files\McNeel\Rhinoceros\6.0\Plug-ins\SectionTools (fbdb1d7f-8cfb-42c1-9858-87cb6315932c)\2018.4.17.851\SectionTools.rhp “SectionTools”
C:\Program Files\Common Files\McNeel\Rhinoceros\6.0\Plug-ins\Flamingo nXt 5.0 (fd53f8c4-546d-47d1-8820-e66c97645a97)\5.5.18031.1000\5.5\Flamingo.nXt.rhp “Flamingo nXt 5.5” 5.5.18031.1000
Hello - the first thing to try is to download the latest version - Help menu > Check for updates.
Is Undefined 6 Undefined some kind of trial version or is it the new Corporate version?
@pascal Unfortunately these days I live in a village and I have limited access to internet to download the updates, so this is not an option. I suppose that for my current project I can move back to my Rhino 5 academic version.
@siemen I am not aware of any corporate version, does a version like that really exist?
Thanks a lot, I will return to this when I will be able to update
@zabrielza, your first screenshot shows Undefined 6 Undefined which is believed to be a cracked version. Corporate edition == cracked, is what @siemen is hinting at…
@jesterking, thanks for the info. I admit that I am a bit confused as I believe it is a trial version. I am going to repost here in a few days that I will have installed the trial version and have tested the section tools. Thanks
