I’ve just setup recently on a new computer running on Windows 10 Rhino5. Here’s the issue: whenever I maximise the window, either by dragging the handle to the top of the screen, or by using the button, a certain section at the top of the screen doesn’t recognise Rhino’s existence. This section usually appears a little above the entry box for the command prompt, but sometimes includes the area of the command prompt completely.
Everything is unresponsive above this area: the Menu bar (File, Edit, View…), and even the handle itself (minimize, maximize and close buttons included). The handle is drawn but does not pick up mouseclicks; instead, the mouseclicks “fall through” the window to whatever that is behind it.
Keystrokes are registered properly; only mouseclicks are not.
If I undock one of the toolbars, and redock it, the functionality of all these things come back again, and the menu items will redraw if I hover above them. If I restore the window (make it smaller than maximised) then everything redraws.
Has anybody come across this weird bug before?
