Hello - I do not think Rhino has ever imported the sketch geometry. I think construction geometry refers to the planes. I’ll see if I can find out more.
If you are using SW yourself and can make a simple box with its input curve and save that off, just attach the file here and we’ll see if we can make that curve come in.
Here is the example of a part that I usually receive, which is already drawn by the designer
it is a simple panel cut with a cnc with a line which resumes the axis of an engraving in V shape for a folding.
The panel is made this way because it is normally machined directly with solidcam which manages the 3D format.
but for my part the have to rework it in 2D for the machine it in DXF
I automated the 3D> 2D transformation step with grasshopper
however it is impossible to see these engraving lines appear.
My question is, in the solidworks file there is a rectangle and a solid, is that correct? I just want to confirm what is supposed to be in there so we know what to look for in reading it in.
