I am currently working on solidworks, creating drawings of assemblies. These drawings also include views of the parts that are in this assemblies.
After export in .dwg format, all I get is a drawing only made of curves and surfaces, references to the parts is lost.
Is there a way to export both assembly drawings and parts that are used in the same assembly, in order to keep the references in rhinoceros?
Hope it was clear enough.
That seems like a Solidworks export issue. Can you export to STP? This works well for Catia, the parts come in as named Blocks. Similar to Revit - Autocad export.
From a solidworks drawing sheet, my only export options are .dwg and .dfx, which I already tried.
Exporting one of my drawings to stp gives this:
The assembly is only 1 block
Here is what I can get, I am still not able to open the parts individually, all I can do is ‘stretching’ the parts, I can’t clic the lines inside the part.
