One thing I found in the Rhino to Revit workflow is the geometry volume in Rhino compare to Revit. They don’t give the same values! The geometry is pushed to Revit with Rhino.Inside
So Revit knows a 1m cube has 1m3 in volume - Correct
Has anyone else experienced this? I’m thinking if we use Revit to do quantity takeoff and the geometries are coming from Rhino then the data would be unreliable.
If I exported the rhino geometry to sat and insert it into a revit family file, it looks like this, and I have tried all the sat export settings and they export all the same
Hi David - I don’t really have any idea what Revit is working with - the Rhino volume seems pretty consistent, comparing variously meshed versions of the brep - none has anything like the numbers you indicate from Revit.
Thanks for sharing the geometry.
I will investigate why is this happens.
One thing you can do if you trust the value that comes from Rhino is create a shared parameter called ‘Accurate Volume’ in the ‘Generic Model’ category and using the Volume component in Grasshopper compute it and attach it to the resulting element in Revit.
