I want to build the honeycomb structure, but I need to materialization some of the hollow parts. You see, one is to materialization the structure passing through the trajectories; the other is to randomly materialization some of the hollow structure.
Hello
Your demand is not easy to read and seems to be a duplicate of a previous question
There is a difficult in the whole hexa grid is integrated with some thickness and how do you choose the part. But my idea is that we use the scale tools to get the thickness of hexagonal meshes and then randomly materialize the hollow structure. Do you think it is possible?
In the honeycomb structure, how to materialize the hollow structure randomly?
My structure is the physical structure of honeycomb, with thickness.
Yeah, my friend
For my question can’t be resolved, so I reposted for help.
Xin Shu
Department of Mechanical Engineering
SUNY Binghamton, Binghamton, NY 13902
Email: shuxin@binghamton.edu
Every thing is possible. But you are not enough clear. You had many helps and it seems you didn’t use it. So make what you want with rhinoceros. If not try to give the parameters you want, the logic, some drawing showing the logic … And some script
Grasshopper is good for parametric thing. Parametric need parameters.
You are right.
I am just getting into Rhino, so there are a lot of problems.
For my problem: one hand, the way I think of is to scale to get the thickness of the hexagon, on the other hand I want to fill(or solid) the hollow hexagon randomly by using dispatch.
Hey @shuxin I strongly recommend you take some time to try and be more clear.
Upload more and different images of what you want. Not always the same.
Model what you want in Rhino, and take a screenshot and upload it here. After that people here can help you replicate it in Grasshopper.
I can notice English is not your native language. Thats fine, but you need to be more clear. Mayebe write in your native language and use a good translator or ask a friend for help.
Goodluck.
Thank you very much for your advice. I’m from China, and I’m really not clear about my English expression. I’m sorry. I re-upload some different pictures. Thank you again, dear friend.
------------------ Original ------------------
Your words are very warm, thank you very much. I have just come to the United States, I am still working hard to learn English and improve my English skills.
Dear forum friends, this is a modified model and method obtained by combining two friends for @HS_Kim and @diff-arch. In my model, the solidified hollow structure is controlled by a short line. But I use Solve intersection events for two curves, I can only achieve one intersection at a time. But there are a lot of lines in my picture that intersect the hexagonal sides. So I need to modify it in my Grasshopper program.
Thanks again for all the people.
Honeycomb Structure_V12.gh (17.6 KB)
