Honeycomb sturcture 3d
Hi everybody,
I’m trying to create a honeycomb structure with two for me important parameters:
wall thickness and adaptable to every surface.
I have been working on the surface adaptability but somehow unfortunately I can not
make to to the wall thickness.
I would highly appreciate if anybody could help me out :slight_smile:
Greets,
G
honeycombsturcture 01.ghx (314.7 KB)
honeycombstructure 01.3dm (2.9 MB)
There’s not really much in those definition except somebody else’s vb script? I would try offset on surface and work from that, but I have no idea if that will work.
Hi.
Check this out.
honeycombsturcture 01_re.gh (21.8 KB)
You are the best! Thank you so much ! :smile:
Made my day :slight_smile:
Can I ask you one more question… do you know if its possible to change to scale of the hexagons from smaller ones to big ones ?
greets
2012_09_19-poincare-doyle1
something like that
As long as you keep rows and columns it will be possible, just deform UV of your surface, so deform your surface. Here it looks like a disc. I just rebuild a surface with 3 and 3controls points and degre 2.
