I am trying to put together a parametric roman rib vault in Grasshopper to be used in BIM (ArchiCAD).
First I construct the surface and then I add the side surfaces and finally I am adding the top surface and join all the breps, which results in a closed brep according to Grasshopper. After this I am using the brep to mesh component. The problem is when I am importing into BIM app and trying to make a section, it appears not to be solid. It has to be solid to make a nice proper section. Any suggestion for a better process?
any advice on this?
3. Attach minimal versions of all the relevant files
vaulted_ceiling_2019Dec16a.gh (19.3 KB)
P.S. Purple group.
vaulted_ceiling_2019Dec16b.gh (18.1 KB)
P.P.S.
Hi Joseph,
Thanks very much for your solution. Actually the archs have different height in my case. But actually I am interseted in the theory. Why is my closed brep not solid? As I said somewhere I have read that in Grasshopper closed breps automatically considered solid, but not in my case. What do I do wrong?
keresztbolt.gh (51.3 KB)
Ugh. Thatâs not how the Romans did it, did they? I can see several reasons your model fails to create a âClosed Brepâ. The four bottom corners taper to nothing. The top inside touches the top outside. I might have looked a little deeper but one look at this code and I want to close the file and run away!
P.S. At the far right edge of your model there is a pair of Dispatch components connected to a Merge. The âD2â input appears to be the âClosed Brepâ you want?
I dont undestand why are you saying it not closed. Grasshopper says it is closed.
See attacehd image.
I said it is a âClosed Brepâ, as shown in the image I posted. Why arenât you using it?
See the very first image I have made in ArchiCAD. If it was really closed the model would be solid isnt it?
Maybe it is a bug in GrasshopperâŚ
any idea that a closed brep supposed to be solid or not?
I may be wrong but there is no real solid in Rhinoceros. It is not a solid modeler. Rhino use BREP representation so Boundaries, if there is no âfreeâ edges the surface is considered closed.
I donât know Archicad, but what uses this software uses ? Mesh or Brep ?
If Mesh Joseph gave you clean mesh that are closed (all edges connected to 2 faces).
Clipping plane in Rhino works well with @Joseph_Oster meshes and Brep
So as a conclusion it seems more related to Archicad.
The âClosed Brepâ in @Balazsâ model is sketchy because the four bottom corners taper to zero thickness, which wonât behave well as a âsolidâ .
vaulted_ceiling_2019Dec21a.gh (16.0 KB)
Are you really sure it is not soild modeller despite Grashopper has dedicated solid operation commands, like boolean difference, etc�
It is not my model. Is there way in grasshopper (maybe a dedicated command) to check that the model is watertight (solid) ?
