Solid difference is missing one of the components in my model
Hello, I’m at a complete loss, this solid difference is missing one of the components i’m trying to subtract from it and I can’t figure it out, What I’m trying to do is subtract the wavey part from a box to get what I need, sadly I need it to be done this way due to measurements and what happening is circled part isn’t subtracting from the box and I can’t figure out why. if anyone can help I would massively appreciate it.
Wall of SmoothnessP03.gh (105.0 KB)
Wall of SmoothnessP03.3dm (15.6 MB)
Simplify your file and only upload the gh file
As @Quan_Li said, you should have simplified your grasshopper file to only the parts needed to illustrate your question and internalise all needed geometry.
Took me a few minutes exploring your file to get to the problem area.
You could eliminate the 3 Trimmed Surfaces, they aren’t causing problems but are not needed here.
Wall of SmoothnessP03_re.gh (1.3 MB)
(geometry internalised)
Subtracting this
From this
Gives this result (unexpected area circled in red)
You need to adjust the construction and/or placement of your cutting shapes to correct this.
If you look at the intersection curves from your breps, you can see the problem
These are the non-planar faces in your cutting breps. I would expect these 2 faces at the bottom to be planar.
Edit: one possible solution (I don’t know how critical the dimensions of your geometry are).
Wall of SmoothnessP03_re2.gh (1.3 MB)
-Kevin
