I use Razer Tatarus programmable keypad to consolidate all the shortcuts and macros from various 3D software and it has been working great. But I’m running into conflict with Rhino, even after togging off the command prompt.
The only resolution is to quit Razer Synpase or not link it to Rhino. Otherwise some simple keyboard shortcuts like copy and paste don’t work in Rhino. Any workaround for this? Thanks
You should explain in more detail what this conflict is.
FWIW I have used for years a programmable keyboard. I put in a couple of Rhino commands, it has always worked nicely on Windows (Mac version of Rhino has just too slow command prompt that it doesn’t work properly).
More context and details would definitely be in order - there are so many idiosyncratic ways that this stuff can be put together.
I’m also using a mouse with programmable buttons, and have had great luck with it in Rhino - Logitech G600. This mouse has two modes - one which runs in a “tethered” fashion where it relies on a piece of Logitech software running on the computer that issues the commands associated with the various buttons (this enables switching command sets depending on the software based on the which has focus in the OS). The other mode (which I run exclusively) - has the commands as standard key-presses programmed directly into the mouse - so nothing running on the computer is reinterpreting things (i.e. the mouse can move to a different machine without any vendor apps and the same functions work).
Based on what you’ve described - it sounds like the synapse software is intercepting and blocking your keystrokes from the keyboard? Is the keyboard also part of the Razer system?
I’ve figured it out. Synpase had the wrong file path for some reasons, it auto detected bootstrapper.exe as Rhino 8. It’s working correctly now it’s pointing to the right path. Thanks.
