Soft-edit / proportional editing tutorial?
Specifically, I’m looking for tutorials on how to modify non-symmetrical, non-geometric shapes (because I found some of those, and they’re edge cases that’s useless to me, as I do free-form surface modeling).
Does anyone know of any?
Is it possible to use any soft/proportional editing in Rhino with a view based drag modification? UVN directional modification? Only affect a certain control point selection? Can you soft-edit something that’s matched with history (like tweak G2 rows of control points but not G1, for example)?
I honestly can’t get anything to move in a predictable way (or even at all) so far…
Ok, my troubles stemmed from having 0 in one of the U or V distance options. That stops the soft-edit surface tool from working, apparently. Setting a value to 1 instead makes it work…
Took me a very long time to figure out, since I essentially wanted to do this:
GIF
I figured out the first step finally, but I don’t think there’s any falloff control in Rhino?
I fell for this again!
Why is the default value of the distance 0 when that makes the tool stop working???
But also, what the heck is this:
That is not a surface normal proportional modification!
I’m sorry but there’s honestly no other words for it now: How lazy and inconsistent is this tool!?
Ok, 3 years later I finally figured out how to soft edit in Rhino.
You do it by cage editing (which can even be done on a subset of control points):
GIF
But again, this is a hell of a lot of clicks to set up…
