When I am trying to work on a surface (draw a line for example) my mouse keeps snapping to the lines and points in the background. how can I prevent this from happening?
Please help. Thanks.
Hi.
Activate the “On Surface”-Osnap. Alternatively, orient the CPlane (=construction plane) to the surface in question.
I thank both of you for the answers. But unfortunately, it does not solve the problem. The on surface snap or setting c-plane helps a lot but still when I draw the line it keeps snapping to all the lines which are behind that surface. Is this normal? cause I have seen my partners working in rhino and it doesn’t happen on their computers…
That is normal. It will happen a lot less when you switch off the persistent “Near”-Osnap, and only use that as a one shot when you need it.
