I’m wondering if anyone knows a way to get a smoother transition on the edges at the widest point where it kinks out? I’ve tried adding cross sections and tried 2 rails, but this is the best I’ve been able to get. It sounds simple but i’m missing something.
Thanks
The semicircle at one end can be nicely approximated by a rebuild to degree 5 and 12 points (for 180 degrees) I rebuild the short arc at the other end the same - it does not need that many points itself but it should match the rebuilt half circle so that a sweep2 to make that edge is clean.
Thanks for that it makes the edge better.
I was referring to the way the object transitions from the area above the widest point and the area below the widest point. It’s too abrupt.
Try building two curves representing the desired shape of the edges. Then use Sweep2 with those two curves as the rails and the three cross-sections as the sections.
Hi Paul - you’re being appropriately picky, I would, say but given the, well, messy surfaces this is hard to fix…you can get rid of that little crease but if you look over at the top of that spoon shape, there is a whole-nother thing to deal with. I recommend working on simplifying your input curves and and understanding continuity, and the tools available for dealing with these, and separating shapes into primary and secondary surfaces.
