Smart Ribbon along mesh
I want to create a Ribbon along mesh starting from a single guide curve
I mean that I want the tape to be dynamic and adapt to both the change of the branches and the shape of the curve.
Dropbox - Error - Simplify your life
The problem with this definition is that the flow deforms due to the difficulty of creating the ribbon following the given path “the curve”
Curvature-Ribbon-along mesh.gh (463.2 KB) Ribbon-along mesh.3dm (71.5 KB)
Hi :slight_smile: is there a method to create a ribbon a long a spine on a mesh (ortogonal i guess) to make a clean split? I managed to get the mesh and curve pulled to the mesh but i would need a clean split in two meshes along that unregular spline. A big patch does not work as well…
grafik
Thanks a loT!
Hello
If you want plugin I have a ribbon tool to do that in Nautilus plugin
Here an example of use and bug in r7
You need a good precision to remove some bugs
cut_geometry_with_curves.gh (7.4 KB)
And if you just want ribbon use Polyline Extrude Both Side of Mesh
make_ribbon_from_curves.gh (7.3 KB)
Or is is also quite simple to dot that with components
Divide the curve
Search notmal for each point
Move point up and down
With 4 points of a segment make a mesh face
Join the faces
