Smart+ Layers — a faster, cleaner layer panel for Rhino
Hi everyone,
If you work on projects with dozens or hundreds of layers, you know the routine: scroll, expand, scroll again, open the properties dialog, repeat. I built Layers+ to make that daily routine shorter. It is a dockable layer panel for Rhino 8 that sits next to Rhino’s own panels and follows the same dark look.
It is free, works offline, and needs no account. The panel has a light and a dark look and follows Rhino’s theme automatically, so it always matches the rest of your interface.
Why use it
  1. Fewer clicks for everyday layer work Every control does something useful with the left, right and double click, so you rarely need a menu:
Eye icon — click toggles visibility; right-click isolates the layer and its sub-layers (right-click again restores everything).
Padlock icon — click toggles lock; right-click locks all other layers (again to restore).
Down-arrow icon — click moves the selected objects to this layer; right-click copies them.
Colour box — click selects, right-click sets the layer current, double-click opens the colour picker.
Object-count badge — click selects only the objects on that layer; right-click adds them to your current selection.
  1. Two-column layout One button switches between a single list and two columns, so long layer lists stay readable even in a narrow panel. The name shrinks first; colour, visibility, lock and change-layer buttons always stay visible.
  2. Instant search One click opens the search box, and the list filters as you type. Closing the box clears the filter.
  3. Layer Configurations (layer sets) Save the state of your whole layer tree — names, hierarchy, colours, visibility, locks, print widths, linetypes and materials — and bring it back later:
Left-click the configurations button to restore a saved set.
Right-click it to save a new one or update an existing one.
Open it in another file and apply a set to add the layers that are missing there. Handy for office standards.
5. Details for each layer Select a layer and see how many curves, surfaces, meshes and other objects it holds. Click a type to select just that geometry type on that layer. Material, linetype and print width are one double-click away and open Rhino’s own dialogs, so nothing behaves in an unfamiliar way.
  1. Light and dark theme, in step with Rhino Use Rhino in dark mode and the panel is dark; switch Rhino to its light theme and the panel switches too, without restarting the plug-in. Colours, frames, menus and dialogs are tuned for both themes, so text stays readable and layer colours are never altered.
  2. Clear visual feedback The current layer is framed in its own colour (or the whole row can take the layer colour, with automatic black/white text for contrast). Hover and selection frames, plus total layer and object counts, are always visible.
  3. Keyboard friendly
Key Action
Up / Down move through the visible layers
Enter make the selected layer current
F2 rename
Esc deselect / close dialog
The panel never uses the Delete key, so you cannot delete a layer by accident. After Enter or Esc in the search or rename box, the keyboard goes straight back to Rhino.
  1. Right-click menu on any layer Set current, select layer objects, change or copy selected objects to the layer, rename, duplicate, toggle visibility/lock, open colour / material / linetype / print width, delete.
Who is it for?
Architects and interior designers with deep sub-layer trees
Product, jewelry and industrial designers who isolate layers constantly
Anyone who shares layer standards between files and teams
download from https://www.food4rhino.com/en/app/smart-layers-faster-cleaner-layer-panel-rhino
Requirements and installation
Windows, Rhino 8
Run Install.bat from the download (it asks for administrator rights and installs to C:\Program Files\Smart Plus\Layers).
If the panel does not appear, run _PlugInManager in Rhino, install LayerPanelPlugin.rhp from that folder, and restart Rhino.
Open the panel with the command LayerPanelCustom, or right-click any panel tab and choose Layers+.
Feedback
This is a first release and I would like to hear what works and what doesn’t. Bug reports, feature requests and layout ideas are all welcome — please reply in this thread.
Thanks for reading, and happy modeling!
