Small BUGS Rhino 8 Beta
In the rendering panel I like to collapse some of the sections that I don’t frequently need to accsess. The last section “Rhino Render Advanced Settings” is the only section that doesn’t stay collapsed. Every time you switch to another tab in the panel, this section will be expanded again when you come back to the rendering tab.
In menu bar of the render window under “View” the options “Toolbar”, “Effects Panel” and “Show Rendered Image” are enabled by default. As expected they disappear when disabled but this state isn’t saved. When starting a new rendering they are alway enabled again.
when replacing blocks one can choose to replace either the one selected or all instances of that block. though when selecting all, only the visible ones are beeing replaced. those on hidden layers don’t get replaced. not sure if this is the way it is supposed to work. I’d prefer all - including all hidden instances - to be replaced. if not then then I suggest a third option.
block replace options:
  1. only the one selected
  2. all visible
  3. all visible and hidden
sometimes a fourth option like “all on current layer” may be helpful.
Not a bug but a wish regarding the layer state manager:
It would be nice to have the option to save the state of sublayers beeing collapsed or expanded. When there are a lot of layers and sublayers in a document this can be quite helpful.
Hi @hitenter,
The Rhino Render Advanced Settings bug is now fixed.
https://mcneel.myjetbrains.com/youtrack/issue/RH-77302
Regards,
John
NICE! thanks for taking care of this one.
Now I hope this one is next:
Hi @hitenter,
I’ve logged your request.
https://mcneel.myjetbrains.com/youtrack/issue/RH-77323
– Dale
I’ve logged this:
https://mcneel.myjetbrains.com/youtrack/issue/RH-77329
John
Hi @hitenter,
I have just fixed RH-77329. The fix will be available in Rhino 8.1.
Regards,
John
Great thanks for fixing this.
Though only 8.1?! That sounds a bit like you plan to release 8.0 pretty soon.
Hopefully we can get 8.0 out “soon”. We’re trying to limit fixes to 8.0 to critical issues or ones that we are very confident about. The 8.1 release candidate will be available the same day 8.0 becomes available.
Small bug ?
Often when I quit Rhino (no crash) Rhino process is still alive …
I noticed it while installing Beta update, shutting down computer.
And I get a windows alert
I’m forced to kill the task
Let me know if I need to send any log file for this issue
Best regards
Just need to add that my display was laggy last time
file (178Mb)
Just opened the file again, after quitting, display speed is ok
