We are experiencing major issues when using Rhino in combination with our network. We hope you can help us resolve this, as an enormous amount of time (and therefore productivity) is being lost due to waiting times.
Opening an 800 MB Rhino file directly from our network drive takes approximately 2 minutes and 30 seconds.
Opening the same 800 MB Rhino file directly from my local SSD takes 30 seconds.
Saving an 800 MB Rhino file directly to my local SSD takes 20 seconds.
Saving the same file directly to our network drive takes 2 minutes and 30 seconds.
When copying a file via Windows Explorer, we achieve a transfer speed of approximately 90–100 MB/s.
The above-mentioned Rhino model has very few external references and textures. When opening and saving models that contain many external references and textures, the time required to save directly from Rhino to our network location increases even further. In addition, some colleagues regularly work with models that are larger than 1 GB.
Of course, we understand that there is a clear difference between working locally on an SSD and working on a network location. However, the loading and saving times are, in some cases, so extreme that working centrally from a single network location for all colleagues is simply not feasible. Rhino becomes so painfully slow when saving and loading that, in some cases, this can take up to 20 minutes.
Plug-ins:
Chaos Bridge for Rhino, 3D connexion mouse, D5 Live sync for Rhino, Datasmith exporter
Can someone please help us and provide info on how to improve performance with saving Rhino files directly onto network through Rhino?
Below, you will find the specifications of my workstation.
Rhino 8 SR29 2026-3-4 (Rhino 8, 8.29.26063.11001, Git hash:master @ bbd126f84fcdaf7a974615b7c9f4f8667571c147)
License type: Commercial, build 2026-03-04
License details: LAN Zoo Network Node Checked Out
Windows 11 (10.0.22631 SR0.0) or greater (Physical RAM: 63GB)
.NET 8.0.25
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA RTX A6000 (NVidia) Memory: 48GB, Driver date: 3-17-2026 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 595.97
Accelerated graphics device with 4 adapter port(s)
OpenGL Settings
Safe mode: Off
GPU Tessellation is: On
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 3-17-2026
Driver Version: 32.0.15.9597
Z-Buffer depth: 24 bits
Total Video Memory: 49140 MB
C:\ProgramData\McNeel\Rhinoceros\8.0\Plug-ins\Datasmith Rhino Exporter (d1fdc795-b334-4933-b680-088119cdc6bb)\DatasmithRhino8.rhp “Datasmith Exporter” 5.6.1.0
C:\Program Files\Enscape\Enscape.Rhino.Plugin-net48\Enscape.Rhino8.Plugin.dll “Enscape.Rhino8.Plugin” 4.17.0.1175
C:\Users\0b5f9\AppData\Roaming\McNeel\Rhinoceros\8.0\Plug-ins\D5LiveSync (e0d5e210-02f6-4ee9-a2b0-1675e225d958)\D5Conv.rhp “D5 Live Sync for Rhino”
C:\Program Files\Chaos\Bridge\Chaos Bridge for Rhinoceros\V8\ChaosBridge.rhp “Chaos Bridge for Rhino”
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.29.26063.11001
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.29.26063.11001
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.29.26063.11001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.29.26063.11001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.29.26063.11001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.29.26063.11001
