I possess a GH file featuring sliders that generate Tekla objects. While adjusting the sliders in GH, I observe instantaneous modifications in the real objects. However, upon utilizing the Grasshopper Component obtained from Tekla Warehouse, the changes don’t promptly materialize. They seem to take effect only when I shift the slider to 0 and then revert it to the desired value. Could someone offer assistance in resolving this issue?
Hi Vu,
If your inserted component instance is selected in the Tekla model, it should update immediately when you move a slider.
Does this happen only for a certain definition? In that case, are you able to share an example definition where this happens?
Cheers,
Sebastian
