Is there a way to control the TsPipe component refresh in the Tekal Grasshopper component?
The objects in the pipeline should update each time a component instance is inserted or modified in Tekla.
In case you’re not creating objects with your definition, the GH application could be more appropriate to use. Then you can just hit ‘Run’ in the GH component dialog and the objects in the pipeline should be updated.
-b
The code would be creating objects into Tekla again but i will look into the grasshopper application too.
I was trying to reference Construction Objects, but as this made the pipeline component run or seconds or minutes, I switched to including them in my model object selection and thus the need in the other question for the Refresh option.
